hey guys, i got piping, silicon hose and pod for my jazz, but at the back of the stock filterbox, there is a sensor, where do i put that? its on a L15a
https://www.dragtimes.com/images-cla...0339935204.jpg
short ram intake is just waste of time...oem airbox is the way better.
nah just had everything at home so i decided to do it,
i plugged the sensor into the rubber elbow but shows engine light
i think i need to drill a hole in the pipe and put silicon hose from the engine to the pipe.
not too sure
what happens if i dnt drill the hole? does it do any harm?
I don't see why it wouldn't work if you drilled the hole in the rubber elbow like in the picture you posted. Unless you didn't transfer the old connector attatched to the OEM airbox onto the rubber arm?
The engine light usually turns on when it is disconnected, once you put it back into the connector it should turn off.
yeah, theres a sensor for the back where the elbow is, but the silicon hose that goes into the pipe. i dnt know if i need that
you can either drill a hole in your pipe or use a breather.
this is what i did to mine
http://img42.imageshack.us/img42/8357/img6569b.jpg
