im a noobie, just asking how do i change / get rid of the antena.
its always up even when i turn of the car freaking 1 metre high on the rear.
r u talking bout an electric antenna? normally the pioneer headunits dnt have a seperate antenna trigger wire so as soon as the deck is on its up, if that not the issue it may be broken? more info man, thanks
it goes up, but doesnt come back down and makes a clunking motor sound when it goes up and down, so fkn annoying T_T
either go s2k antenna or unplug the antenna motor so it wont go up
Yeah its fkd then, u got the option of going s2k antenna as mentioned, unpluging the antenna motor and having shit reception or for about $40 you can get an aerpro replacement antenna mast that you can swap over with ur damaged one, you may have to open the antenna casing and remove the broken bits of white toothed plastic "rope", or if you remove the whole thing and take it to a car stereo place they should be able to do it for you for pretty cheap.
Thanks
