Dear all,
I've had this brake problem to about a 8 months already from the first time i tried to change the front brake pads and did not push the piston back in properly because i used an incorrect clamp, i drove down the road and back and noticed that i lost some fluid, i checked the master cylinder and it is still between the min and max mark. So i went to check the caliper, it was dripping with brake fluid, i opened up the caliper and saw that i damaged the rubber cone surrounding the caliper piston. There is a small rip in the flexible rubber seal which extends out as the piston travels ouwards,onto the brake pad. After this i removed the entire caliper out and put it all out on the bench to re-assemble the internals and reinstall it onto the car. I bleed all the brakes from back to front, left to right. Ever since i have not lost any brake fluid as a result of this noob accident. the brakes work fine but the brake pedal has too much play. I would have to press the pedal for about 5 cm down until the brakes begin to engage, once they are engaged, the brake is stiff, not spongy and the pedal does not travel all the way to the floor. During this 5cm pedal stride if i were to press the pedal continously, i hear the woosh sound which u get when u press the brake pedal continously when the car is turned off. I was concernedi screwed up the bleed and brought it to honda for a proper brake bleed, it did no good but wasted 70 bucks and gave me a 30k fluid replacement :). went home and I though there was air in the brake master clyinder and bleed it at the master cylinder with rags and towels. I had some time today and adjusted the brake pedal to the max (closer to the floor) and now the problem is still there.
i'm a poor uni student and preety mechanically minded so i try most services at home in my garage given i have all the tools, but this time i must say i exhausted all my options and did it properly according to the shop manual and the pedal is still ....fcked. so i'm asking for help from all those honda techies out there for some helpful advice on what i should do. broken master cylinder? damaged pushrods? damaged brake booster, i seriouly got no idea now, ... lost
thankyou in advance
