What is the difference between the VTI and VEI ?
Advantages and disadvantages?
from a quick search:
http://www.ozhonda.com/forum/showthread.php?t=99430
vei is vtec-e, more economy than performance
vti is standard vtec
the engines differ.
VEI =
D15Z1 (may differ local market)
* VTEC-E
* Found in:
o 1992-1995 Honda Civic VX
o 1992-1995 Honda Civic VEi (European Market)
+ Displacement : 1,493 cc (91.1 cu in)
+ Bore and Stroke :75 mm × 84.5 mm (3.0 in × 3.3 in)
+ Rod Length : 137 mm
+ Rod/Stroke : 1.62
+ Compression : 9.3:1
+ Power : 90 hp (67.1 kW, 91.3 ps) @ 5600 rpm
+ Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4800 rpm
+ Valvetrain : SOHC VTEC-E (3-4 valves per cylinder depending on RPM)
+ VTEC Switchover : 2500 rpm
+ ECU Code : P07
+ Fuel Control : OBD-1 MPFI
VTI =
D16Y1
* Found in
o 1992-1995 Honda Civic VTi (AUS)
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Power : 129 hp (96.2 kW, 131 ps) @ 6600 rpm
+ Torque : 107 ft·lbf (14.8 kg/m, 145 Nm) @ 5200 rpm
+ Redline : 7200 rpm
+ Valvetrain : SOHC VTEC (4 valves per cylinder)
+ VTEC Switchover : 5000 rpm
+ Head Code : P08
+ ECU Code : P28
Well if you are comparing to the EK vti, then it's pretty much the same except the EK vti is a 1.6L (88kw) instead of 1.5L.
i assumed he meant the eg vti vs eg vei
Get the VTi, or if possible get an Si with the D16A8 DOHC non-VTEC (take this from an EH VTi owner). The DOHC will give you much better power if you're going to mod it, and it's not worth taking the D16Y1 just for the VTEC...
never get the vei... lol
