I bought some Fog lights for my 2007 Honda Civic off ebay. Seemed pretty simple to connect but Ive run into trouble with the wiring harness inside the car - the instructions become very vague around here so I have to guess.
I've mounted the lights and connected them to the single wire plug that I located near the water reservoir. Then I ground them and put the bumper back on. I'm now left with final harness ( image 01 ) -
Attachment 12501
Its obvious where the switch goes and also were the relay plugs in.
I was also given a 15A fuse to put in location 6 on the fuse box. No problems there but then I'm left with that 6 pin blue plug and that one pin brown plug.
Now it all looks pretty straight forward - I found a single pin brown plug just dangling there near the fire wall - I presume this running to the front of the car where I connected the lights earlier ( image 02 )
Attachment 12502
and then I just plugged in the 6 pin to the only location in the fuse box that it can possible connect to ( image 3 ) .
Attachment 12503
I then grounded the ground wire. Unfortunately they dont work!!!! What have I done wrong?
The 6 pin is getting a 12V signal when I switch the parkers on so I;m pretty sure I got that right and the switch lights ups no problems. It even seems to generate a 12V signal out of one of the leads running to the relay ( it turns off and on when I operate the switch ) but I'm not getting any power coming out of the relay down that single blue wire to that single pin connector. Should I be? Maybe the relay is stuffed?
Anyone got any ideas?
