hello,
could someone please show me how to remove the factory immobilser from my ecu its from a US spec S2000 37820-PCX-A01
Cheers
hello,
Cheers
Just a quick question,
Is this doable? have you seen it somewhere?
More importantly why do you want to do this?
my guess is the ECU won't fire up as it needs the go ahead from the immobiliser ECU/key immobiliser coil. pretty skeptical about this, will it work/is it worth putting a s2000 ECU in an integra?
BINGO ECU isnt firing up car need IMMO removed,
Why wouldnt it be do able you can remove them from other honda ECU
ECU's change as they advance in time
as I mentioned in the PM I sent you, If you can take a photo of the inside of the ECU I might be able to help you with a bypass modual for either the FX01 or HIC immo. not sure what system the S2000 uses, if it one of the two then I can help you, if its the type 3 immo system you may be in trouble.
if its this type of OBDIIb ECU
http://images.google.com.au/imgres?i...a%3DX%26um%3D1
then I can disable the Immo for you with an add in PCB
