hi guys. im thinking of buying a jdm itr 96 steering wheel for my integra LS DA9.
would you know if it fits or would i need to buy a boss kit
cheers,
tony
cheers,
tony
i am told that EF civics and DAs are the same interms of steering wheel fitment and have seen EFs with this steering wheel so it should fit with no problem n no boss kit needed as the Dcs are slightly different, however enough for u to use d wheel but it will be just ever so slightly loose.
what about dc2 integra ? is it straight fitt. im confused with the boss kits and stuff what if you do have a boss kit, is it still straight swap ?
yea dnt see y it shudnt fit the only probs we got apparently is with the srs type r ones, n i had a momo hub for my saas steering wheel on my old DA teg n d hub was actually for an eg civic n it worked fine however like i said b4 it was jst however a tad loose n had it on for 2 months b4 it went n still no probs
ITR steering wheels fit straight onto the steering column, the 'boss' is built-in.
So if it doesn't fit, no you can't get a 'boss kit' for it.
If it does fit it'll be peaches.
ohh yeaaaaa 4got to include: dat d boss is built in on d itr wheel
cheers geeang
