I have changed the steering wheel on my EG and the horn is not working... ANy idea?
are you sure you put all electrical connections right? postive to positive, earth to earth. also check the fuse, you might have shorted the connections while trying to install the aftermarket steering wheel.
did you remove anything else apart from the steering wheel?
On the steering column side before you put the boss kit on, there is a little spring loaded grounding point, you might need to bend that check if its grounding out the boss kit.
the old one is a eg gli airbag steering wheel
I changed it to something i got off ebay but either way it should work as steering wheel doesnt produce any sound anyway just the wiring...
i will check all the fuse later
Fixed your title.
