damaged sump? Losing oil pressure at idle & low RPM
Hey there
I'm after some help and advice regarding what i think is damage i have sustained after my oil sump took a decent knock.
when driving recently i was exiting from a highway to a petrol station and drove over an uneven piece of road at the entrance to the station where I felt a heavy knock at the front of the car. I knew the sump or the frame at the front ahd been hit, was hoping it was the frame but suspect it was the sump.. So I pulled up, got my petrol and turned the car back on to head off again when i immediately heard a mechanical grinding type noise coming from the front. At the same time i saw my oil lamp start flickering.
I drove the car around the back of the station where there was plenty of room to drive around a bit. What seems to be happening is that from idle up to about 1500 rpm the oil lamp will come on, above these revs it goes off and stays off. The car itself does not feel any different at all. The noise is not permanent, it only happens when the revs are increasing or decreasing between approx 800-1500 rpm.
After bout ten minutes or so of driving around trying to deduce the problem I decided that I should be fine to finish my trip home (150km) as most of the driving was on the highway and when I came to a stop in town I would keep the revs above 1500. I got home no problems however dont want to drive the car again until I have sorted it out.
Only thing i can think of is that the knock to the sump has damaged something inside it perhaps causing a lack of oil pressure in that rev range. or the knock has dislodged something else or damaged the oil pump perhaps?
It has been 4 days now and there is no oil leak at all. Is there an oil pickup or something that could physically have been damaged which could cause what I am experiencing? The car was running perfectly before hand so I am assuming that the knock is to blame for it otherwise it would have been a big co-incidence if something else has broken at the same time! The oil and filter were changed around 1500km ago.
Any suggestions etc are much appreciated :thumbsup:
