hey guys
it seems not all B series air con compressors bolt up to a b20 swap on an EK
i am running a b18/b20 setup
any advice on what units from which engines will fit?
hey guys
thought it depended on the bracket itself? not so much the compressor unit
u need a vtir type off a civic or integra
bracket that mount your compressor. B16a or B18c bracket should be fine
the bracket you have on your b20 requires d series compressor :)
as far as i know, you just need this bracket (part no. 38930-P54-000). you can reuse everything else.
