does anyone noe how to fix this
check your battery.
Is it only one side or both sides that are flickeing ?
Check that your ground is secured assuming that it's HI/LO kit.
If it's only one side, switch the ballasts around to see if the problem stops when you change the ballasts around.
it is more than likely the ballast.
Check the grounds bro
Ballast usually.....
it will eventually fail and you will need a new ballast like myself and nepolian said.
Flicker or off momentarily?
Could be bad bulb?
Could also be wiring from the ballast, happened to my old HID set.
