Carbon Fiber Whale Dik intake repair
Hey All,
I have a carbon fiber whale intake on my DC2R, and ever since I got the car at Christmas, there has been a whistle under accelleration.
When I removed the intake the other day to replace my rear engine mount, I had a closer look at the intake, and there is a small crack, and no there is a hole that allows air to bypass the whole intake and entre the trottlebody mouth..
I was going to fill it up with some resin like Araldite, but seeing as the whole thing is carbon fiber, should I be using carbon fiber resin to fix it? it is in a spot where it won't be visual anyway.
The rubber on the air breather intake from the valve cover is stuffed too, so I also need to know where to pick up a replacement.
Cheers
Chris
