Need to install Alpine head unit, can't use wiring harness...
Hey guys,
I'm installing an aftermarket Alpine headunit into my EK1 at the moment. I can the replace the stereo itself easily enough, its just the wiring I've had trouble with. I've browsed the threads and seen none that explain how to actually use the wiring harness itself. The ones I bought are from Autobarn and are likely cheap and bad, but bear with me.
There are various wires not connected such as the power, battery wire, etc. I am unsure what needs to be connected to which wire. I have tried several combinations to no avail.
If anyone has encountered and solved a similar situation, or used the Autobarn wiring harnesses before successfully, then it would be great if you could explain it to me. As much as this is a noob question, if anyone can help me out it would be much appreciated.
Thanks guys!
