i need help what is the different between oem clutch and standard exedy clutch?? which one is better?
This will probably help:
http://www.ozhonda.com/forum/showthr...-vs-heavy-duty)
from my experience when i changed over from oem to exedy it was a big difference the car gripped on harder
and also friction point was much more sensitive compared to oem but not much of a gap between the 2.
At the end of the day a new clutch is also beteer then an old clutch. Depending on your car as well..
What car do you have? With every clutch change you either have to machine your current fly wheel orpurchase a new one.
I hope i made sense :)
