Trying to install HID's
i tried to installed my HID's plugged in right 1 working fine charging up and everything , then when i put in my left one i plugged up wires every things fine i turned it on both lights would light up for about 3 seconds then go out . It kept happening then when i tried putting back the normal lights the left headlight aint turning on now what do i do?
Did you use a relay so that the HIDs were powered straight from the battery? If you didn't and instead relied on the headlight wire to power the HIDs, then you might have fried your wires to a crisp. Check your fuses too.
i checked the fuses they were normal but now my headlights only turn on for a couple seconds then turn off i have to rely on my high beams at night i got to go to auto electrician tomorrow
