stance on a s2k
about to get my s2k a set of bbs' in 17x8.5+40, 17x9.5+40.
anyone got photos of similar setups?
my cars tyre tucking(springs) on stockies ap1s.
will i need to make any mods? or will it fit smick?
also thinking of running 215/45/17 and 235/40/17? too much stretch?
all input is appreciated.
Fronts should be ok, rears might be stretched a little.
Imo who cares about tucking tyres go for grip, 235/45 fronts and 255/40 in the rears.
good luck with rear fitment, you'll need a shitload of camber and rolled guards to make them fit and be driveable.
Guard rolling, and fender pull/flare with alot of camber dialled in too. Bumper tab relocated. Definetly not an easy fit, and if you are tucking the tyre you will rub.
im on 18x9.5 + 38 with 235/40 on the rears but needed the the guards rolled and at least -3*camber!
is it even possible to find 235/40 spec in 17" tyres in aus?
KU36, KU31 or Falken ZE912 come in 235/40/17 not sure if tyre shops carry them might have to be ordered in.
Yeah my rears are 235/40/17
i've got 225/40 stretched on a 10inch fine. that's an option if you need a little more clearance.
You should be fine, 3 degrees isn't really a shitload of camber anyway :P
As long as you get tyres with thin sidewalls and 235's it should clear pretty easily. Defiantly need a roll but it would look better with a roll anyway :)
Thanks guys for all your input.
I'm pretty busy ATM with life but once I paint the bbs, I'll post a picture of the end result.
