Hi guys i just drained my coolant out of my car and flushed the radiator. Topped it up with coolant and let it run without the cap. Bubbles started appearing which i heard was normal. Then a tad of foam at the top. My car started to rev and de-rev going from 1800 revs to about 1200 revs and bouncing back and fourth. Is that the fan? or is it not normal? My heater setting is still on hot if it makes a difference now =/ Thanks
I suspect there's still air in the coolant pipes and its causing my idle to bounce.
