http://www.tempetyres.com.au/product...tto&part_no=29
Can someone explain to me what they all mean?
If it helps I'm looking at 19x8 for my euro, Hopefully they will fit =)
sorry, but u just gotta give us more info to go on... like where did u get it from? wot are u after exactly? tire sizes for 19x8 aftermarket rims?
at the moment just looks like a heap of mumbo jumbo to me :D
but i think sum of the numbers correspond to tire sizes, i.e.
225/35 ZR19
235/35 ZR19
first number is the tire tread width in mm - 225mm
second is the percentage of the tread width which is the height from the inner diam to outer diameter of the tire (man my technical terms are sick :D) - 35% of 225 = 78.75mm
last is the size rim it's for i.e. 19inch
hmm, hope that helps ;)
19x8 will fit.
Your range of tyre width would be from 215 - 255 prolly. Don't quote me tho. :)
I think you should look at what offset also. Maybe ring the tyre place and ask them if they have the right offset in that style. They will also be able to give you a better estimation if it will fit or not also.
