Anyone know do i need to change the D-brackets if im swapping over to the Type-R swaybars and also the rear Links or not?
And also the size of Type-R swaybar sizes
Rears? IIRC they're 22mm. Yes you'll need to change the D bracket to fit the swaybar. Standard endlinks should fit.. all EK endlinks are compatible. Correct me if I'm wrong :)
Fronts and rears, for better overall stability
