hey guys. im wondering wether coilovers for a dc2 will fit on a 1990 da9?
cheers
cheers
You'll need DC2 front forks, but other than that they should bolt up fine. I know you said coilovers, but keep in mind that stock DA9 shocks are about 6cm longer than stock DC2 shocks.
ok thanks for that. big help. cheers
correct me if im wrong,
but i think you need dc2 rear lcas and front forks can be oem da9
you don't need dc2 rear lcas ...
if you use dc2r suspension you need dc2r (itr or eg6) lcas
ahhh, ok..
thanks for correcting
Will eg springs fit onto da9 shocks? Or can I use eg shocks on the da9?
EG Springs should fit fine, from memory they are also a tiny bit lower than DA9 ones. The rear shocks on EG as stated above are different as they are an eyelet type just like the DC2R. So you'd need DC2R rear LCA's.
i might b confusedhere by u need the front lcas, for the shock? because its different lengths is that right?
so the rear as long as you have a dc2 (not type r) with the fork shock you wont need dc2 lcas, then you can use stock da9 for the rear
