Originally Posted by
dougie_504
I don't know this brand, and if I were you I'd consider Bisimoto for a D-series cam as strong opinion seems to be that this company invests the most time into the D-series.
Whether or not you build the rest of the engine will probably determine what cam shaft you should get.
If you're leaving the engine standard (valves, valve springs, retainers, cam gears, bottom end etc) you might want to consider a 'Stage 1' cam shaft which is normally a straight swap for your stock one and will allow for a small power increase but without compromising normal driveability.
If you're building the engine you could consider Stage 2 (for daily driving) or a higher stage for racing.
Most modifications you do to Hondas (especially on any VTEC engine) will provide you with power gains mostly noticeable in the high-end of your rev-range. If you want low-end power in your SOHC D-series then keep it stock.
