Hi there! What gauges I can put into my non turbo car?? Water temp?oil temp?oil pressure?vacuum?boost I don't think so....volts??
vaccuum is a waste mate. If i were you i would run oil pres, water temp, and if you have a decent stereo run a volts gauge to. Or run none :D
vacuum is only a waste on a stock NA, a built NA i might need to monitor it.
but yeah if its just for looks just go Oil temp and Oil pressure, dont get water temp if ur stock 1 works just fine.
the stock water temperature doesnt give you a reading in units... getting a proper guage that reads in degree's will give you an accurate readout.
However, i'd rather have oil temperature anyway, water temp is a by product of oil temp
Unless you do track work. I wouldn't waste money on getting gauges.
Clocks are cheaper and would serve a better purpose in a stock car
You could have one for Melbourne, one for Tokyo and one for New York... JDM, AUDM, USDM =)
there is also oxygen sensor gauges but seriously.. gauges are a waste of money and expensive and your just increasing the chances of someone stealing it by having them..
