Need new diff mounts, left one closest to the exhaust is cracked! any suggestions for where to buy from, and any aftermarket ones that are good?
AND
your favourite gearbox oil, for the smoothest gear change!
AND
OEM fluid is awesome but then again I've never tried anything else haha
Hardrace diff mounts from JDMyard are awesome.
thxx, will ring up and ask, and i think ima try royal purple this time
I use redline and its pretty good. I wanted to try royal purple though
Firmer than stock, more responsive and there new.
Yeah, am I right in saying the diff will be more stable and won't move as much which should help with traction but might up vibrations in-cabin?
Yes. Not too much more vibration with the hardrace.
I might have what your looking for spare... PM me..
Redline did wonders for me... But will try Royal Purple next.
Solid collar inserts for the factory mounts aren't a bad option either. Pretty much fixes the diff in a solid position, yet still uses the rubber to dampen some vibrations. Equally the same job as replacing all your mounts only a cheaper alternative.
