Clutch Pressure Issue
Hey Guys,
Not sure if i can post this here but here it goes, i have 94 CRX DEL SOL (B16a2), and it has phases where my clutch feels very soft like no back pressure much and especially with the brakes, the brake point slowly sinks to the very bottom of where the pedal can go... especially on hot days..
Ive had issues with the slave cylinder before which we've fixed .. for now hahaha but theres no leaks and the fluid seems topped up..
Any reason for this its causing crunching and uncomfy transmission when im driving around..
Cheers..
well I'd say it's the master cylinder, and if you had a bandaid fix the slave then fix that properly too
same goes with the brakes, probably the master cylinder for that too
