Does this work?
Hey people,
If i have a monoblock amp that is both 2ohm and 4ohm stable that only has one input for one sub. Then I have 2 subwoofers, one at 4ohm setup and the other at 2ohm setup and plug them both into that one input on the amplifier. Will both subs move? Is this extremely bad?
disconnect both subs & use only one of em, NOW. if you wanna run 2 then use ones that have the same impedence. are your 4&2ohm subs dvc or svc? besides the VC impedence rating, are they even the same brand/model/series subs? got any specs on your amp?
