coilover adjustment EP3R
hey guys was respraying my wheels n thought id muck around with my coilovers
its got buddyclub racing spec coilovers
i want to set it to its lowesttttt position it can go just for a foto n quick spin then bring it up to just above the tyre...
anyway to clear things up coz im kinda noob with coilovers it has the spring on 1 part then a locking ring under that then 1 ring down on the bottem....if i want to go lower what do i adjust? i tryd adjusting the top 2 rings by cracking the 2nd 1 ( the 1 thats under the 1 thats under the spring) if that makes sense l0l then turned the spring up, then tryd down...didnt notice anything really....
also to adjust the damper stiffnes do i tighten the nut on the top in the middle?
sorry for being noob l0l
You have to adjust the bottom ring to change the height. To change the spring rate the top 2 ring will change that.
aw ok so if i compress my spring thats spring rate and then the bottem 1 is to lower....what about the rears theres only 2 there?
