Should i change my oil...i know services are every 10kkms, but just oil and oil filter?..also...ne one reccomend some good brake manufacturers, i gotta replace mine (civic vtir)
Cheers'
Sam
Cheers'
Sam
as in the manual short trip every 5000km
brakes manufacturer? you mean calipersor brake pads?
calipers ->well endless is good if you can afford it, but stock ones are still functioning for its purpose.so why need change?
barke pads-> stock oems the best:)..use the wrong ones and it cook and warp your rotors:)
too clarify, just need the pads...i feel my braking response and stopping time is slower than 12months ago....hanny's would do oem pads ?
Bendix if u on budget, not bad and priced
Oil: Change the oil every 5000, every second time, change the filter.
Pads: Bendix is your best bet - but the existing ones may have glazed and still have plenty of meat on them. If so, get the rotors machined and the pads deglazed.
Steer clear of EBC pads - they don't like Hondas.
I've got Bendix at the rear and OEM's at the front. They stop the car pretty quick. OEM's are the best to use as a replacement, the only problem is that they are so expensive. In most cases people just go out and get aftermarket ones cause the OEM's cost so much from Honda.
hanny's has the oems:)
OEM pads = NISSIN
my pads on rear are OEM and done over 180,000kms..
Bendix for front - but they dont last long and make HEAPS of dust !!
