Originally Posted by
hmetro24
Probable causes:
- Battery terminal connections loose or corroded. Try to move them and check again. Baking soda diluted in some water or plain coca cola can get rid of some of the corrosion and help it start.
- Battery discharged or faulty. If you canīt get your headlights on or they are very dim this could be the cause. If you have a multimeter check the voltage in the terminals, it should be way more than 12 V.
- In automatic transmission equipped cars the tranny is not completely engaged in PARK. If the tranny has problems try it in Neutral. I have seen this so many times...specially, women are prone to do this :lol:
- In manual transmission equipped cars the clutch is not completely depressed, if the tranny is in first. Try to press the pedal or put the tranny in neutral.
- Broken, loose or disconnected wiring in the starting circuit. Check with multimeter to see if the starter is getting 12 V at its terminals when the key is in the ON position.
- Starter motor pinion jammed in flywheel ring gear.
- Starter motor solenoid faulty.
- Starter motor faulty. In this case, as in the previous try to hit the starter with something like a stick, a ratchet, etc. and try to start again. In most cases this will work, however after some time you will be beat the hell out of the starter and it wonīt start..time to take it out dude.
- Ignition switch faulty. Sometimes you can find burn wires on the wires or maybe loose connectors.
- Flywheel teeth worn or broken.
- Blown fuses in the inside fuse box or in the engine fuse box. Although a long shot on this troubleshooting, simple things like this can be the main cause.
Not mine but get them from google
