Hey guys,
So I installed H4 HIDs into my Jazz, all works fine BUT when I high beam, there is not lights. Anyone else have this problem? Any fixes?
Hey guys,
Did you buy a kit with both Low and Hi beams? cause the cheap ones usually only have low beams.
that sounds about right, is there a bulb I can change or nah?
you need new bulbs and different loom for the hi/lo controller.
Just be aware that you will get a defect notice for putting HID lamps in a car that is not designed for them.
To be legal, they must be projector type headlights with a washing system and be automatic self leveling.
That is correct.
However they do require 3 "defects" to actually give you a notice, I have gone past countless booze busses and been pulled many times with only 1 cop ever commenting that my car shouldn't have HIDs in, and he even asked if they were HIDs, I guess because the jazz is a newish car it doesn't seem terribly out of place unless you run like 8k HIDs or something.
do you guys know where the adjustment nut is for the GD3? pictures maybe?
Buy yes if your reflector style headlights were designed for halogens then putting HIDs in will just give you immense amount of glare even if you do have Casper shields.
I believe the highest model yaris comes with HIDs or was it the corolla? either way im quite reasonably sure it doesnt have the washing system on it either. The general go is (not legal) that if your car is new enough, cops are not as suspicious about it and would be less likely to give you a defect over it as opposed to something that is blatantly out of place, such as an eg/ek. It would be unlikely a cop would pull you over on the basis of HIDs, it would be moreso because of other reasons.
