Factory ride specs
Hi guys,
I'm trying to work out some suspension calculations and i need someone who has factory shocks and springs to give me mesurements from edge of guard rim(wheel arch) to the centre of the wheel hub, not ground clearance. I need front and rear measurements, it won't matter if you have aftermarket wheels. Your help would be much appreciated, thanks.:thumbsup:
hey man.
just went to have a look at my S for you, and hope these are the measurements you are after.
i measured the distance from the wheel arch to the wheel hubs along the horizontal plane and the measurements comes out as follows:
front wheel arch: 38cm from the centre of the wheel hub to the front and 38cm from the centre of the wheel hub to the back
rear wheel arch: 36cm from the centre of the wheel hub to the front and 36cm from the centre of the wheel hub to the back
lemme know if that's what you're after, if not i can have another look for you.
vertically from the top of the wheel arch to the centre point of the wheel hub it is:
front wheel arch: 35.5cm
