Cbr250rr blinker issue
Hey guys i dno if this is in the right section but meh. Got a cbr250rr n its got aftermarkey cf led rear blinkers fronts r stock..anyway when i firat bought the bike they use to blink very fast ( like when a car has a blown blinker it goes faster) anyway been riding it then 1 day it went normal pace well stoped riding for a while coz had to do brakes..after i done my brakes i hosed the bike down coz the brake fluid anyway my blinkers wuldn work then i would ride at a certain throttle position or speed n theyd work now n then...has any1 had issues?...suggestions what to check?
Check they're secure and not coming loose at certain vibrations. Check for shorts in the wires.
The right front blinker assembly moves a lil but still works at certain throttle..how would i check for shorts
Check the wires to see if the conduit/cover has frayed and caused electrical current to leak if it's shaking during motion/vibration. Will be fiddly.
Ok so found a relay near the temp gauge disconnected it n blinkers worked again but highbeam didn so im gna try a new relay n hope it fixes it
Uldn find a new relay so plugged old relay bak in n everything works woo
Lols. Probably need a love tap...
ye stopped working again...that relay was for the highbeam function...so it must be a wiring/connector fault somewhere but meh im selling it tomorrow anyway :( going to miss my lil cbr... thanx guys for the help cheers
