Hi guys
i have a base '03 dc5 the 5sp shifter is pretty sloppy and has a bit of play when in gear i've read i can fix this by replacing the bushings on the shifter cable to metal over the current rubber? is this right?
i'm about to order some from here http://www.speed-source.net/ as they're pretty cheap :thumbsup:
has anyone else done this? does it tighten up the shifter and make changing gears betterer?
cheers!
