CU2 HID log lights doesn't turn on when lights are set to automatically
Guys,
Recently purchased a set of HIDs from maxvision australia and I noticed something NQR.
If I have my lights set to Automatically turn on when I start my engine, sometimes only 1 of the fogs turn on. Sometimes both are not working. However, having said that if I manually turn it off and on again, both will work.
This only happens when I start the car. If I have it on Auto and turn keep the key to ignition only then fogs are on. Then I go to start the engine and they both turn off. Something about the ignition is causing this. Does anyone else have the same problem?
The problem was also encountered on other cars that have Auto lights switch.
I suspect it has something to do with a fail safe in the ballast if anything. (The standard Honda HID lights work without a problem)
Anyone else have this problem or know how to overcome this?
