Lowering of the suspension
Hey guys,
I've heard that if you lower your car, it'll stuff up your "bearings and joints" as a friend put it. Apparently because the car wasn't designed to be at those "angles" ?
Is that true?
Or is it only excessive dumpage that'll destroy your car? If you lower it, say 2" or 1.5" I'm sure it wouldn't effect it?
Also regarding ride height and stiffness, does the ride comfort significantly change? Like will your ass muscles get really tank after driving a "lower" car?
I know that if you're lowering your cars on springs, its generally good to replace the shocks as well, however if your car is pree much brand new, and you want to lower it.
Would it be sufficient to just replace the springs since the shocks are pretty much brand new?
Regards Michael
