CU2 Electric Front Seat Adjuster Broken
Slight issue hoping for a real easy solution. Put the drivers seat into the furtherest back position to put ski boots on then while getting gear from the roof pod kicked the electric adjustment nob. Result broken nob. Anyone know if there is a way to manually adjust the seats? No settings no use, didn't reset them when the battery was changed (wishing I had).
Will take to a dealer ASAP, just have a several hours drive with 4 adults in the car before I can get there. Need a temp solution if possible....
