ok so im doing a b18 conversion to my eg civic and i got type r cvs with the motor but aparently there to big to fit so i have to get gsr ones.. but when i rang a place today he told me to just simply knock the abs ring off and they will fit????
you mean the HUB of these driveshafts ? They will be 32mm (96-98 JDM , 96-00 AUDM) or 36mm (98-00 JDM).
What hubs / brakes are you putting these into ?
Maybe he is talking about the ring in the Drive shaft,
Hey I'm using vti hubs and brakes an its a 98 type r
you need to get driveshaft that is 32mm to suit your car.
You can use with civic vtir, integra vtir or even gsi
In regards to ABS rings, You can run abs drive shaft on a non abs vehicle
