P2K ECU rpm pinout? Can't seem to find it on the ECU
P2K ECU is a piece of shit. There isn't an RPM pinout and the best I could find is known as the VSS. I have done much research on this and still I can't get a straight answer on how to wire up VAFC2 to this ECU. I can't get the RPM wire to work correctly. It is wired up to VSS following the ecu pinout provided in an old post from ECU-MAN. Everything else is wired up correctly, but not the REV. Because it is wired up to the vehicle speed sensor, all I am getting is perhaps the rev's of the wheels instead of engine revolutions. I am not sure what it is reading, but from google, it diagnoses the axle speed. So basically, how do I wire the green RPM wire from the VAFC2 to the ECU. Anyone who can help.. please do! Thanks for reading this lengthy post
http://www.ozhonda.com/forum/showthr...P2K-ecu-pinout ( i used this and wired it up accordingly )
