		Weird Cabin Fan
		Hey guys my cars electrics seems to be playing up, my car is a 1989 ED6 (D15b) civic and when i need to use the fan inside it doesnt work until i click over to 3, 1 and 2 doesnt work and 3 is too loud. Wat seems to be wrong? i tried dismantling the switch and re-soldered all the copper connections but that didnt do the trick. Any ideas?
		What about cleaning up the wires at the fan end to, just an idea, its possible the fan speed controller is buggered...
		what i do is open a window insted :D dose the job with my old ed :P
		My ED's fans work fine, albeit pretty damn weak.
		see an auto electrition, can be mighty expensive if you try fix it n break it more lol
		mate your heater fan Resistor is blown, to achive each speed there is a resistor per setting to slow the fan down. so your 1 position resistor is blown,  the resistor block comes in 1 peice with all three speed resistors on it, so just buy a new one from you r local honda dealer and put it in your self. you will find it screwed into the heater box behind the glove box, if your unsure, remove your glove box, take a photo, ill point it out to you.
		cool thanx man i'll take a pic and show it to ya...and i'll give it a try at the same time too. :)
