Crunch
I'm having a real problem when I shift from 1st to 2nd at high rpm quickly it make a bad crunch noise, even when I make sure the clutch is in al the way, I was told by a mate who had the exact same problem in his AE86 that automatic tranny fluid fixed his problem but I thought it would be a bit sketchy.
I have changed the tranny fluid with castrol manual stuff, but I still have the problem.
Any ideas on how to fix the problem. Thanx.
most likely bad synchros unfortunately. Copped too much abuse. time for a rebuild...
No truth to the auto tranny fluid thing?
the american's rave on about Gm syncomesh stuff. ive give that a try but its only a temp solution.
sounds like synchros problem to me... if it only happens on 1st to 2nd gear
O well, guess it's time for a rebuild:( :( , looks like the body kit has to wait for a while.
