Mfactory final drives - pro series
MFACTORY FINAL DRIVES - PRO SERIES
Now Available for Immediate delivery - Experience the MFactory Advantage
Take your performance to the next level with the MFactory PRO Series Gears. Recognizing the demand for transmission components that can withstand the extreme shock loads produced during Drag Racing, MFactory Competition Products are proud to offer our range of top-tier competition level gears.
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel and put through our own proprietary heat treatment process, the MFactory PRO Series Gears are the pinnacle of off-the-shelf performance gears for today's Sport Compact.
Through the use of leading-edge Solidworks 3D CAD & Cosmos FEA software, our advanced gear geometry helps to increase tooth strength, reduce friction and, most importantly, minimize parasitic drivetrain losses. Transmissions built with MFactory PRO Series Gears transfer, on average, 1-2% more power to the ground over our competitors!
Part of the testing criteria for our gears included extreme hot-lapping and tuning sessions on loaded dynos which ensure that not only are our gears strong enough to handle the shock loads encountered during Drag Racing, they are also durable enough to handle the variable loads encountered during day-to-day Street Driving.
Whether used standalone or alongside our PRO Series Gear Sets, our redesigned PRO Series Final Drive Gears (Semi-Helical) increase drivetrain efficiency and are the final link to fine-tuning your race transmission.
http://i64.photobucket.com/albums/h1...DriveStats.jpg
- Made from imported Japanese Steel
- Forged and Cryo-Tempered for unsurpassed toughness
- State-of-the-art Wide Peen Cleaning; significantly more advanced than regular "Shot Peening", and used by several F1 and Le Mans teams
- Proprietary Ti-Moly Coating increases surface hardness, increases thermal resistance and lowers friction
- Designed to withstand the extreme shock loads of competition-level Drag Racing
- Advanced gear geometry designed using industry-leading software puts more power to the ground
Honda B16A2 Final Drive Fitments: Will not fit models equipped with Factory LSD
Honda B16A2/16B/18C 4.923: Offering a revised design over our previous generation 4.928 Final Drive Gears. Forged from stronger steel with a 50% larger tooth profile yet almost 1kg lighter!
http://www.teammfactory.com/images/c...finaldrive.jpg
http://www.teammfactory.com/images/catalog/b49fd.jpg
http://www.teammfactory.com/images/catalog/s2kfd.jpg
FITMENT
PART NUMBER FITMENT
- Honda B16A2 PRO Final Drive Gear - 4.05
- Honda B16A2 PRO Final Drive Gear - 4.267
- Honda B16A2 PRO Final Drive Gear - 4.533
- Honda B16A2 PRO Final Drive Gear - 4.600
- Honda B16A2 PRO Final Drive Gear - 4.785
- Honda B16A2 PRO Final Drive Gear - 4.923
- - Honda B16B/18C PRO Final Drive Gear - 4.05
- Honda B16B/18C PRO Final Drive Gear - 4.267
- Honda B16B/18C PRO Final Drive Gear - 4.785
- Honda B16B/18C PRO Final Drive Gear - 4.923
- - Honda K-Series PRO Final Drive Gear - 5.08
- Honda K-Series PRO Final Drive Gear - 5.46
- - Honda S2000 PRO Final Drive Gear - 3.90
- Honda S2000 PRO Final Drive Gear - 4.44
- Honda S2000 PRO Final Drive Gear - 4.57
PM or Email for current pricing
Beware of MFactory copies in the market
Buy only original MFactory products from an Authorised Dealer or risk getting inferior quality products.
