[EK] : How to check is the low fuel light working or not
Disclaimer:
The following is provided as a GUIDE ONLY, and neither myself nor Ozhonda take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Note:
This is my first write up on DIY section , please excuse my English/Grammar
Aim:
To check is the low fuel light work
Required:
Couple of basic tools ,
Spanner set
Screwdrivers
wire to test
1:
Remove the rear seat (check other DIY if you don't know how to)
2:
Remove the access panel by undo those screws
http://i41.tinypic.com/13zblt1.jpg
3:
This is the plug that we're looking for , pull the cover off , undo the plug
http://i43.tinypic.com/1t3lso.jpg
http://i43.tinypic.com/250jevt.jpg
4:
Here's how to test it ..
- use the spare wire and put it in the plug between yellow/green wire and black wire
- turn the ignition ON , but! not start the car
- if the light is still working , it will show on the cluster
http://i43.tinypic.com/amd0zo.jpg
http://i39.tinypic.com/2uf6arr.jpg
- if the light's not showing , check the bulb in the cluster
5:
if you want to check your fuel gauge ..
- put the spare wire in the plug between yellow wire and black wire
- just see if the needle moving that's all !! do not let it hit the full , this might damage the gauge
http://i39.tinypic.com/2lx9e3d.jpg
6:
That's it , let put everything back
Hopefully , this will help someone who might be interested to know if their low fuel light is working without taking a risk and run it down till there is no fuel at all
See you again next time
