B18C Blowing smoke only during vtec under load ??
as the title says my b18c is blowing smoke but only under load in vtec, Any sugestions or things i could test/try would be great
compression test was done 10,000kms ago and was 170ish across all 4
I have a short list of mods running with a stock ECU but nothing to major
skunk tunner series stage 2 cams
edelbrock manifold
68mm TB
i'm also running an oil cooler in prep for turbo and have added 3 washers under the oil pump relief spring to raise the pressure
