Hu Shorting Lights?
QUICK ANYONE!
Anyone got any tips?
my Hu is working sweet, during the day
but when i turn the headlights on.. it cuts the music out.. but the Hu still runs... jsut cant hear anything?!
Anyone got any quick tips?!
The high beams work, when just holding them on,
its when i click on the headlights..
Also the clock isnt showing anymore..
The car is a 99 EK1 sedan civic btw
and does anyone have the schematics for a Kenwood AX498AR its the stock hu from a Civic...
There is a wire missing/loose somwhere...
trying to work out which one!:S
wtf??? did u wire them in urself?
no probs.. working through it now.
There were a couple of wires not hooked up right.
Is there a wire that could be connected to your ATT (attenuation) wire coming out of your Hu?
Very strange problem indeed
yes there is a Att cont. wire running off my HU...
Not sure where it should go. (no manual)
going to go have another look now
Ive got it all working btw...
Just now, the dash lights are on whenever the car is on..
Gota work out which wires which..
yeh.. get a test light..
check ur parker light wire..
detach ur headunit from the loom..
then.. get the test light.. ground it..
turn on the headlights.. check which wires has power..
if it does.. keep the light there.. turn off headlights.. if it turns off. that the PArk/headlight wire.. then check where u wires it wrong to!!
Ken
no worries guys ,
worked it out... was just a couple of blown fuses..
:) its all good now ;d
