I roughly know that my wheels are currently 15" and have 4 nuts.
http://www.nengun.com/work-wheels/work-emotion-cr-kai
those are the wheels I want to purchase...please help?
Thank you! ^_^
Thank you! ^_^
Look for 4x100. Just means there are 4 studs and the PCD is 100mm (diameter of a circle going through the 4 studs).
The link you posted i'd go with the 15x7 +37 or +44 is easiest fit for dc2, 205/50/15 tyres easy fit no need to roll or anything with a moderate drop
I also have Potenza Adrenalin RE001 right now >.<
just saying, might help :)
CB Wheel and Tyres Pty Ltd.
My brain hurts a little bit
stop using them phaggy ass emotacons.
yes they'll fit but get something phatter then 5.5" wide. will look sunken as all fuk.
FUUARKKK HIELLASUnK bruh
http://www.vlturbo.com/images/galler...meet-point.jpg
6.5-7" with a moderate offset is good
Over at Stancegays that's probably a very soft offset lmao.
OP
I recommend 15x7 +35ish. Anything more and you'll probably end up stuffing around with adjustable camber arm setups and guard rolling. So as charliebrown said consider the 15x7 in +37 (wheel will be fitted more 'outwards' of the guard) or the 15x7 +44 (wheel will be fitted inside the guard more).
im pretty sure my friend has 15*7 +42 or something with his DC2 and they fit fine and look alright.
Yeah that's because anything +35 or greater on a 7" rim is an appropriate and sensible offset. Once you lower that offset and height it gets harder to keep it functional.
