Removing fuel injector?
Hey chaps, i want to trial fit another fuel injector to see if it seats withing the rail and manifold on my d-banger, but dont know exactly how to go about it, any tips or diy would b great :)
Id assume it would be same for any other b-series or k-series engine
they would be same shit with b-series
pop the fuel rail off, grab the injector and in a twist/pulling motion, the injectors should pop off. it's just held in by o-rings so it might be a bit stuck from the dry rubber.
The fuel injectors are secured into its place by the fuel rail with the help of 5-6 bolts (10mm). You might need to move some of the line brackets to reach a few of them but after you remove the bolts, you should be able to pop the rail off. It may be hard at first - but a quick even tap would do the trick. Don't scrap your arm now. Lol
Relieve fuel pressure by removing the fuel cap first, and have a rag hand as it will piss a bit of fuel out. In order to see if the injectors fit - you need to tighten the whole thing up again with all seals in place and prime the pump and check for leaks (ON position). Un-clip the harnesses carefully, by now they'll be brittle - and don't' forget to unlock the locking pin (slide both ends out of the groove).
Goodluck.
thanks guys totally forgot about this hahahaha, will try it out when im free later on the week :)
Planing on trial fitting wrx and few other injectors in
