I have a issue with my Euro, While acccelerating sometimes around 50kmp/h, it seems to feel as if im on a bumpy road, but im not :S so its basically the acceleration is chugging. Any suggestions on why this is happening?
Is the clutch old? Sounds like it might be slipping?
http://www.ozhonda.com/forum/showthr...11#post3467311
this post may help you.
Actually my 04 cl9 lux manual sometime got that problem when accelerating around 40-50km/h. I suggest you to check if it is the driveshaft issue.
It is a drive shaft issue. This happened to mine.
Here is my original post about this...
http://www.ozhonda.com/forum/showthr...ox-Issue-Shake
I've got a Automatic Euro, i was told it was the coil pack, but if it was it would of died out straight away, i changed sparks so it cant be a misfire, and so far i got told it was Intake, Throttle, or Exhaust sensors
Also have the engine mounts checked.
Maybe fuel related... fuel pump?
back then i had an issue like that when cruising through school zones at 40kmh....car would feel like it was chugging bad. Read up on it and was told the transmission fluid needed to be changed. Been fine since, coz like every service i get the transmission fluid changed...LOL
Alright ill get my fuel filter and trans fuild changed :) Thank you so much !
