that should fit fine on a CU2. Have a look at this thread:
http://www.ozhonda.com/forum/showthr...-offset-wheels
+44 may be too high of an offset for a 9.5" wheel and can cause the wheel/tyre to hit the suspension, so be careful and don't get an offset that is far too high (or you'll need a spacer), or an offset that is far too low (unless thats your thing ;) )
By the way, poke is how much wheel/tyre is actually outside of the guards, and this is what 30mm of poke looks like:
http://www.eurocosm.com/Application/...n-Deere-lg.jpg
*assuming stock height and 0 degrees of camber :P
