The NEW Wheel Woolies Kit in Stock!
We are sure you have seen or used the Wheel Woolies before or even possibly wanted a set!
The ability of having 3 brushes that will clean safely and easily on any type of wheel design sets the Wheel Woolies apart from the rest.. From the fascia to deep inside the wheel, to tight spots including the lug holes makes the NEW improved Wheel Woolies Set the best to date!
Made with soft but dense 100% polypropylene bristles the Wheel Woolies Brushes are safe to use on almost any surface such as polished alloy, custom 2 & 3 piece, matte finishes and you just your normal painted alloy wheels. Not to forget you can also use these on the inner arches, exhaust pipes and even grills with the smaller brushes in the set.
The Wheel Woolies Brush Kit comes in a set of 3 for $62.95 and are available in store or for collection at Car Care Products.
http://www.carcareproducts.com.au/im...s/9bapj6ga.jpg
And below as you can see comparing the OLD Kit on the Right side to the NEW Improved Kit on the Left Side you can see that now the medium brush has a bit more "bush" and added length!
http://img.photobucket.com/albums/v4...S/fbb877d9.jpg
The NEW kit contains;
1x Large Brush: 48cm in total length – Brush size 15cm Long, 10cm in width.
1x Medium Brush: 36cm in total length – Brush size 13cm long, 5cm in width
1x Small Brush: 22cm Long – Brush size 9cm long, 3cm in width
For best results:
Rinse your wheel first, preferably with a high pressure cleaner. Spray on the wheel cleaner of your choice and gently work the surfaces of your rim with a combination of the Wheel Woolies to free the dirt and brake dust from all areas. If your wheels are very dirty, we would recommend rinsing the Woolies as you clean. Once you have finished a wheel, rinse the rim clean and also rinse the Wheel Woolies, before moving to the next wheel. Once you have finished, make sure the Wheel Woolies are rinsed clean and allow to dry naturally. And we always recommend to ensure that you wash your wheels after they have cooled down!
http://www.carcareproducts.com.au/im...s/navuwewm.jpg
http://www.carcareproducts.com.au/im...s/87dj6wcn.jpg
http://www.carcareproducts.com.au/im...s/bubhrr3s.jpg
Any questions or help needed please feel free to contact us on 1300-006-007, email: info@carcareproducts.com.au or CCP on Facebook
