which brake fluid do i get for the honda civic vti 2006
any DOT 3 or DOT 4 fluid.
Try HONDA dot 4 fluid.....or go something like This
i use Motul RBF600. you need 2 bottles for a full flush!
Either use DOT4 Honda or Motul ! i don't trust others
for daily driving, Honda DOT4 from dealer is good enough
Just make sure if u want to use dot5, u should flush the system well because dot 5 + dot1-4 = corrosive and burn ur brake hoses.
Factory uses dot4, so stay with dot 4.
DOT 3, 4 and 5.1 are compatible.
DOT 5 is not compatible. If you combine DOT 5 with 3, 4 or 5.1, then the mixture will attack the internal seals, causing it to swell and lock up.
