Originally Posted by
infurNOS
Quick question:
Does anyone know if the OEM endlinks for the DC2R's rear sway bar has rubber bushings that the sway bar connects to?
I know their is a bushing for the part of the endlink that connects to the LCA, but need to know if there is one that the sway bar connects directly to the endlink.
My problem is that i have a whitline rear sway bar with hardrace endlinks. No rubber between the endlinks and the sway bar, which i assume is causing a squeak evertime i go over a bump which has been band-aided with some grease...
